Autor Tema: OCTAGON SF 8008 UHD 4K E2 Drivers Update  (Posjeta: 1668 vremena)
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
  • Chrome 74.0.3729.169 Chrome 74.0.3729.169
Odg: OCTAGON SF 8008 UHD 4K E2 Drivers Update
« Odgovori #15 u: Lipanj 02, 2019, 01:11:32 »
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 01.06.2019
- fix timeshift skip
- improve the function that get PTS from decoder. the right PTS using for timeshift and PVR playback
- change frontpanel driver for led and 4x7led according to the new setup menu of display
- add new frontpanel controls need new e2 updates
Ab morgen in den Images!
From tomorrow in images!
Yarinki imajlardan itibaren!
OCTAGON GERMANY SUPPORT
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
  • Chrome 75.0.3770.142 Chrome 75.0.3770.142
« Odgovori #16 u: Srpanj 25, 2019, 15:13:10 »
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 24.07.2019
- [SF8008] Update Drivers:
- fixed a issue for AC3 passthrough after exit KODI
- Minor Bugs fixed and some issues optimized
Ab heute in den Images!
From today in images!
Görüntüler bugünden itibaren!
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
« Odgovori #17 u: Srpanj 26, 2019, 16:46:48 »
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 26.07.2019
- [sf8008] update dB info ATBM782x (DVB-C/T2)
- [sf8008] add dB info for ATBM782x (DVB-C/T2)
- [sf8008] calculate Signal Quality int.SNR % dB (frontend)
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
  • Chrome 76.0.3809.100 Chrome 76.0.3809.100
« Odgovori #18 u: Kolovoz 15, 2019, 15:52:54 »
OCTAGON SF8008 4K UHD E2 Treiber ( Driver ) Update 14.08.2019
- add support for Blu-ray LPCM
- fix a bug for DVD LPCM
- support for 32bit/8bit/24bit depth PCM audio
The following users thanked this post: mano66
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
  • Chrome 76.0.3809.132 Chrome 76.0.3809.132
« Odgovori #19 u: Rujan 07, 2019, 14:35:20 »
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 06.09.2019
- The updates for "wake on lan" (WOL) function.
- Networking Update
- Hihalt Update
- hi_pmoc.ko & hi-dvb.ko Update
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
  • Chrome 77.0.3865.90 Chrome 77.0.3865.90
« Odgovori #20 u: Rujan 28, 2019, 16:00:55 »
OCTAGON SF8008 4K UHD E2 Update 28.09.2019
- [SF8008] Update AC3/AC3+ Dirver:
- libHA.AUDIO.FFMPEG_EAC3.decode.so
- New Audio Driver Update.
- Fix Audio Stop when Live Stream break or stop.
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
« Odgovori #21 u: Listopad 12, 2019, 12:55:28 »
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 11.10.2019
- Optimise "Audio Auto Volume Level"
- Updated files:
- hi-dvb.ko
- libhi_msp.so
- libreader
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
  • Chrome 79.0.3945.88 Chrome 79.0.3945.88
« Odgovori #22 u: Prosinac 25, 2019, 20:01:26 »
Update Drivers [SF8008] + [SF8008m] :
- Improve the DiSeqC Motor control
- Improve Recovery Menu
- SF8008m mini: use usb 2.0 as sda for multiboot
- Updated files:
- hi-dvb.ko
- apploader
- octagon-linux-4.4.35-20191224 (Kernel)
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
  • Chrome 80.0.3987.122 Chrome 80.0.3987.122
« Odgovori #23 u: Veljača 29, 2020, 22:51:05 »
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 27.02.2020
- [SF8008] + [SF8008mini] Update Drivers]:
- May improve the IR Infrared receiving sensitivity
- Fix a issue for smart card when close the /dev/sci0
- Improve the diseqc send when lnb power on.
- Updated files:
- hi-dvb.ko
- hisi_sci.ko
- hisi-ir.ko
- libreader
The following users thanked this post: makedonche
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
  • Chrome 80.0.3987.132 Chrome 80.0.3987.132
« Odgovori #24 u: Ožujak 15, 2020, 22:52:14 »
Review OCTAGON SF8008 v2 | Deutsch (E2WORLD)
Danke an Gunnar Koser für das Video.
Octagon SF8008 Single, Combo and Twin V2. (in Sales since October 2020)
imporvements:
- Front Display improved
- Material Housing cover imporved
- CPU heathing improved
- Tuner GAIN improved
- Rubber foot use better one
- Giftbox improved
- WOL HW + HW Full Recovery by Recovery Button.
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
« Odgovori #25 u: Ožujak 15, 2020, 23:00:25 »
OCTAGON SF8008 openATV 6.4 KODI 18.6
Link 1:
You are not allowed to view links. Register or Login:
Link 2:
The following users thanked this post: trattore
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
« Odgovori #26 u: Ožujak 17, 2020, 21:53:07 »
OpenEight KODI 18.x OCTAGON (Test)
OpenEight Kodi 18.6 OCTAGON SF8008:
Offline sami noor
  • Postova: 66
  • Thanked: 28 times
  • Chrome 80.0.3987.149 Chrome 80.0.3987.149
« Odgovori #27 u: Ožujak 19, 2020, 23:04:22 »
X-Streamity Plugin (.m3u Player) auf OpenEight
[/color]
Config
Ftp:
/etc/enigma2/X-Streamity/playlists.txt
Open playlists.txt and copy (öffne playlists.txt und kopiere m3u link)
You are not allowed to view links. Register or Login:port/get.php?username=user&password=pass&type=m3u_plus&output=ts
Note; this plugin for all octagon models with open8eight image.
